Is Broadband Plus no longer capped?
My neighbour is signing up for Broadband Plus. He tells me it is not capped. My Broadband Plus is capped at 1GB.
Can I transfer to the uncapped service? I am on a monthly contract. If I do, can I take my referrals with me?
Broadband Plus isn't Capped nor has it ever been (Except the usual usage 'Fair Usage' stuff). Broadband PAYG has download limits, BB+ just restricts the speed of P2P.
Broadband Plus has never had a usage limit, instead it has restrictions on certain things like P2P and usenet transfers.
What account are you on according to the Account Summary page? From your description it sounds like you're on the Broadband PAYG or Lite package (effectively the same thing). If this is the case I think you can upgrade to Broadband Plus for no fee.
You should know that there are restrictions on the Plus package - take a look at the Account Features comparison page to see the differences between the products.
Correction, I'm on Lite! I will set the wheels in motion for a transfer.
And thanks!
That was quick! I'm now on Broadband Plus!
