Irratic page loading
Woke up this morning to find that while I still have my connection (ASDL Home 512) was being rather irratic in terms of page loading...some were loading fine, others I was getting time out errors. After trying the page a couple of times it would work...I'd then try to click a link on a page and it would time out again.
There seems to be no pattern to this and I was wondering if anyone else has the same problem and whether there is anything I can do about it? I'm assuming its a problem at PlusNets end as I can ping my router fine...has DNS gone wonky today or something?
1 REPLY
From a command prompt type ipconfig /flushdns and hit enter.
This will clear your local dns cache. If that dosent work, and if you havent already done so reboot your PC and Modem / router.
