Internet connection drops out
why does my Broadband Internet connection drops out when we receive or make a call on the same telephone line?
KJS
This link may be of help - it is usually the filter or the wiring that could be at fault. http://portal.plus.net/support/adsl/adsl_connection_guide.shtml
tonka
Re: Internet connection drops out
get some excelsus z-420uk-adyana microfilters it worked for me.
Try different filters, are you using a dect phone? as it's important with these to have really good quailtiy filters.
If after this your still having problems, then you may have a fault on your line, this is what happened to me about 18 months ago. Try the filters first, and come back to here if your still experiencing problems.
Aaron
