Internet Gateway
Internet Gateway
Hi looking for a bit of help.
I was messing about with the BT Voyuger router and ip settings on my PC whilst trying to unblock some ports and now I have lost internet connection. I have reset the router and set IP address to auto config. I have LAN connection but my internet gateway says disconnected and I can not to get this to connect.
Please help
Adie
alankay
Internet Gateway
Try resetting the router to default settings .... i.e stick a paper clip into the tiny hole on the back of the router.
alankay
Internet Gateway
Apologies!....yep, that's probably what you meant when you said:
"I have reset the router"
That aside....have you double-checked the most obvious? I spent a good hour once punching in the incorrect log-on information!
Internet Gateway
If you have used the reset then you will have to re enter all the settings into the router again ie password username etc. Does the router lights show it connected to the net?
The do ipconfig /all and see what it says does it give the routers ip as the default gateway?
Can you ping by ip and or by name?
Post the results of ipconfig /all and a ping 194.119.131.66
What O/S are you using? If its xp home when you type ping 194.119.131.66 do you get any strange characters?
