Internet Connection Sharing Problem
Hi all,
I have an ADSL modem from Plusnet. I tried to set up a home network using Internet Connection Sharing, in which one of the three laptops is connected to the modem. The other two are equipped with a D-Link wireless card. I am using a D-Link access point that is connected to the first laptop (ie also connected to the ADSL modem).
I am able to see and access to shared drives between the three laptops through the home network. However, I am not able to surf internet except for the one that has a direct connection to the ADSL modem. I tried to enable ICS on the Wip Tech connection, but I get this error
"Error 765: ICS cannot be enabled. A LAN connection is already configured with the IP address that is required for automatic IP addressing."
I just cannot move forward. Any help will be much appreciated. Thanks.
1 REPLY
RE: Internet Connection Sharing Problem
If you have specified the ip address - manual input,
you have to set up an internt gate way manualy.
