Internal PCI ADSL?
Internal PCI ADSL?
Can anyone recommend a PCI ADSL modem (for a Windows XP macine)? I'd prefer to have this than a USB device, unless someone can convince me otherwise.
TIA
RE: Internal PCI ADSL?
> TIA
Have a look here for a PCI card, updated XP drivers are available for download.
http://www.dslsource.co.uk
Hi There!
I have the speed stream 3060 internal PCI DSL modem and it works great, yes thats right even with the infamous XP. Ive had no grief with it at all. I got mine off ebay for £40 + P&P. The drivers are fantastic and really easy to install, well worth a go!
Its made by a company call efficent networks (part of samsung i think)
E-Bay is the best place to buy them as people are getting them in in bulk and selling them out a a very nice price.
Cheers
Skrib.....
I am using the CONEXANT CHIPSET PCI ADSL MODEM from Dabs, cheap easily setup and seems to be reliable.
http://www.themad-house.co.uk/userreviews.html
is a decent site for info.
> TIA
If you go to http://www.eclipse-computers.co.uk/ they have the Allied Data Tornado 805 PCI hardware modem, unfortunately it's not as cheap as the others listed here, being roughly the same price as an external USB model. Nice, though...
