Intermittent connection with XP & Connexant PCI modem
I have two OS on my computer, XP and ME. With ME the ADSL connection is just about perfect, but with XP it is intermittent--on for 2 mins, then off for 30 secs.
I had terrible problems originally to install the software for the Connexant PCI modem. I followed the instructions to the letter, was told that the drivers were being installed, but then the icons just did not appear.
Can anyone help with the intermittent connection problem?
RE: Intermittent connection with XP & Connexant PCI mode
It's because you are using the drivers on the cd. Go here www.themad-house.co.uk and download the latest connexant drivers which are fully XP compliant.
Just to expand on your problem
I had a **** of a time when i put XP on my system. What happend was, when I installed XP it loaded it's own drivers and when you try and install connexant driver it say's it is installed but no icons. I had to take the modem out and reinstall XP. After which i then plugged the modem in and installed the drivers off the cd, since then it has been fine.
My experience has been that you are better off installing the drivers before you install/attach the device. That way, the device signature is matched against the vendor-supplied driver rather than the MS-supplied one that gets recognised as soon as XP boots and/or the device is detected.
Install drivers, shut down, install/attach device, start up. This seems to work more reliably.
