Interleaving
Interleaving
I have just sign up some new customers and I notice their accounts have
https://portal.plus.net/my/account_maintenance/interleaving_control.html
so they can turn on/off interleaving but my account dosent have the option why?
Plusnet Staff
Plusnet Staff
Interleaving
Is it there now? I've just made a change on your account which may enable the icon.
Essentially the reason for it being there or not is determined by whether or not we know what the interleaving status is on a particular line. On some lines we don't know if interleaving is on or off so in these cases can't display the button.
Interleaving
no still not there I have it turned on
Plusnet Staff
Plusnet Staff
Interleaving
Hmm, strange. I have a feeling though it's related to a problem that's open. Will check up on it.
Interleaving
hi, sorry to hijack the thread but how do i get interleaving turned off, its destroying my ping when playing online Sad
Interleaving
Raise a ticket and request it- will take a few days to take effect and may require a router reboot when done.
Plusnet Staff
Plusnet Staff
Interleaving
On some accounts there will be an Interleaving icon under connection settings to allow you to switch it off (it's not there on all accounts), if not then a ticket will do it.
