Increase ADSL Speeds..
Hey all, wow, this program REALLY helped speed everything up for me.
I would advice you all to have a go, its rather simple to work.
Just click DSL and then Optimal Settings.
You will have to reboot, but hey! its worth it!
http://www.mrtac.plus.com/TCPOptimizer.exe
Enjoy!
Nix
RE: Increase ADSL Speeds..
Anybody tried thisHuh?
Dave.
I've seen this one before and used it. Can't say I noticed THAT much difference but everybodys surfing and downloading habits aren't the same. If you're surfing and d/loading fine then should you use it?
If you feel the need to tweak, go ahead, it's from speedguide.net who know a lot about these things (visit their website to be overwhelmed with info!) but play safe and back up your registry first...you never know...
> Dave.
>Tryed it, pages do seem to load a tad quicker!!!!
And I downloaded a 5 meg file at an average of 61Kbs
> > Dave.
You need Sysyem Mechanic!!.
i have been using this for over a year now,
and you always get software update every month FREE
if you purchase it.
It's the best. tweeks it up properly.
backs all registery settings.. so you can undo things of you do have a problem.
and cleans every bit of ***** from your pc,
including the hidden files that the pc creates
even after you delete things!
You'd be amazed at just how much HDD space you get back, that the normal disk cleaner on Windows won't clear.
System Mechanic: www.iolo.com
Here is a speed test i just did with it.
System Mechanic is 8 tools all on 1 easy to use module. (NET BOOSTER for XP ADSL)
Start Test: 12/09/2002 17:49:22
Test Type: Download 1 megabyte
Operating System: Windows XP
-------------Settings Used------------
[D-Link DSL-200 USB ADSL Modem(WAN)] Maximum Transfer Unit: 1500
[Realtek RTL8139/810X Family Fast Ethernet NIC] Maximum Transfer Unit: 1500
[1394 Net Adapter] Maximum Transfer Unit: 1500
Tcp Receive Window: 256960
Time To Live: 64
Black Hole Detection: False
Auto-Detect Maximum Transfer Unit: True
Maximum number of simultaneous HTTP 1.0 Connections: 10
Maximum number of simultaneous HTTP 1.1 Connections: 8
Tcp Options: 1 - Window Scaling but no Timestamp Options
Fast Retransmission and Recovery support value: 3
Support for Selective Acknowledgements: True
Data Transfer Start: 12/09/2002 17:49:24
Data Transfer Complete: 12/09/2002 17:49:46
--->Total Data Received: 1025.23 kilobytes
--->Time to Complete Transfer: 00:00:22:437
--->Average Speed: 45.34 kilobytes per second
--->Peak Speed: 98.04 kilobytes per second
Jason
