If packetloss/High pings tonight 20th Nov
Then check your not routed via GigabitEthernet5-0.linx2.lon1.level3.net as its giving Bursts excessive packetloss and sometimes no traffic at all. This is outwith PN's control Sad
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Ianwild
Have you got any more data on this, we do have a contractual relationship with Level3 and this is something I would want to raise.
Cheers,
Ian
hmm well packetloss started last night around 5.30pm and came in waves every 1.5 - 2 hours, either about 30% packetloss or no traffic what so ever getting beyond that box.
I didnt bother saving the traces as they would probably fix it before you could hassle them, as they have done in the past.
