If only!
If only!
I only wish I was getting these speeds that a speed test I took earlier says!!!
then I used the plusnet one
then the dslzoneuk one!
I am still on day 6 of my dslmax service I know it takes 10 days to get the line regraded correctly and I synch at 7.6mb/s so hopefully this will go up a bit! will a router help?
Peter
shellsong
If only!
I don't know-- you're as bad as Jeremy Clarkson! Are you a natural born overclocker by any chance? Wink A few people on the forum might kill for that sort of speed! Tongue
If only!
By overclocker did u mean to put something along the lines that I visit Mrs Palm and her five daughters there? would it not be superb 27mb/s!!! mmmmm if only!
