ISP (PPP) light sometimes off...
A few times when I have tried to connect to the internet I have been unable to do so and when checking my Binatone ADSL 2100 router have found out that although the "DSL" light is on the "PPP" light that shows if it is recieving signal from the ISP is off. This is fixed by turning my router off and back on again but I was wondering if an easier solution could be found?
I thought it could be that the PlusNet had gone down and my router had not reconnected auto-matically, could this be the case? I have had PlusNet Broadband for a few months now and this has happened around 3 to 4 times.
1 REPLY
Rich
I have the same problem very occasionally with my ADSL2100 router - but it comes back on within 30 seconds almost every time - I have only had to power-off once in 11 months.
Regards
Richard
