IP range on Premier
IP range on Premier
I have just signed up to broadband plus - but after hearing about the timeouts etc ..... i wanna upgrade (plus using ddyns.com is annoying).
If i was to pay extra for the premier 2Mb line can I also get a /29 range of IP addresses?
1 REPLY
IP range on Premier
Yes, although the usage will need to be justified.
For blocks of 8 or 16, you will need to fill out a Ripe form, for which you can use the following wizzard.
http://users.plus.net/ripe/
