IP address range.
IP address range.
Do any body know what the backup IP address range may be if I use the 0845 backup number, as I need to set some firewalls for machines I use to support the IP address the dialup will come from, as I already have my static ADSL IP address added.
Thank you in advanaced for your help.
Plusnet Staff
Plusnet Staff
IP address range.
If you are connecting on the 0845 number then you'll get the same IP address as your broadband connection.
If your broadband's connected at the time then one or both will have a problem with data transfer. In which case you can use the username signup and password signup and you'll get an IP from the 0845 pool (there's a lot of these so I couldn't say what it'd be.)
IP address range.
Thank you for your reply.
