IP Block Request
IP Block Request
Is there a path in the ticket system for IP block requests? I can't seem to find it in the new look Help.
I'm considering a 4 address block as I would like to run two SSL sites using the default SSL port. Would such a request be acceptable?
Thanks.
IP Block Request
i have been through the help Assistant and cant see a specific path for this. I know it used to be there and it would be handy if they had retained this.
My suggestion would be to raise it via "Cant find the answer" option.
Mean time I'll raise it via the UserGroup and see if the option could be added to the wizard.
IP Block Request
OK, thank you.
