IP Addresses
IP Addresses
All,
Does anyone know what sort of schema Plus.Net uses for DSL IP addresses ?
IE are they changed via a DHCP server, or ar ethey static etc etc ?
Thanks in advance.
Pat
1 REPLY
RE: IP Addresses
> All,
> Thanks in advance.
> Pat
Your account will provide a static IP address but you PC/Router will use DHCP to find out what it is..
In other words, Plusnet use DHCP but you will always get the same address.
Peter
