IE wonn't work
IE wonn't work
Hi
I am new to this service - my problem is I can connect to the Internet but IE will not recognise the connection!!!! Can anyone hep.?
S
IE wonn't work
Simple answer
http://www.spreadfirefox.com/
Chilly
IE wonn't work
When you say you can connect to the internet what do you mean?
What are you using to connect, modem or router?
In Internet Explorer click on Tools - Internet options - Connections.
If connecting via a lan ensure that never dial a connection is selected if not then ensure your connection is shown in the dialogue box, set to default and then select always dial my default connection.
