I will Cancal
I will Cancal
this is ***** my speeds are so slow compaired to my m8s down the road on a different service of coarse
hes on zen i might change
chino
RE: I will Cancal
"this is ***** my speeds are so slow compaired to my m8s down the road on a different service of coarse
hes on zen i might change"
I bet u wish you could spell !!
Have you tried plus.net support?
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
RE: I will Cancal
you must be so thick
i have tryied suport a thousand time disk head yes disk
chino
RE: I will Cancal
Ok..
What sort of speeds can you get from this file?
URL http://205.188.160.44/hansdelans/bj08.ork
i got:
Average Speed 55.89 KB/s
cUnDaLl
p.s. it's aol server
RE: I will Cancal
thanks how do i find out the speed do i have to use dap or something gozilla etc
i have reformated as i though this fault was one of mine i have only got windows installed plus a few others
tell me wot i need to check out the speeds all i use at the moment is asdlguide.org
thanks again
chrisSmiley
chino
RE: I will Cancal
Both of those are fine i prefer flashget but it's upto you..
cUnDall
