I can't connect
I can't connect
For some reason I can't connect to either Plusnet or the BT test login. My modem status is connected yet when I try to go to a website a get the cannot find server page with the following information.
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings.
If you would like Windows to try and discover them,
click Detect Network Settings
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Is there something wrong with my account
1 REPLY
RE: I can't connect
Sounds like its not been activated yet, have you recently signed up and waiting on line activation?? The Line light will often come on a day or three before the line is in fact ready for use and your account activated, if so sit tight, it'll happen Smiley Otherwise yeh there's something wrong Smiley
Oli
