I am I back to 56k or something.
I am getting awefully slow speeds from Browing websites. I try to download something from a HTTP websites speeds under 10kbps. Whats going on +net?
are all sites slow? there aren't any issues reported. How many hops are you getting to plusnet?
Yes all websites are going slow. My usage this months has only been Dec 16 2005 - Jan 15 2006 8.44GB.Here is a WinMTR to plus.net.
| WinMTR statistics |
|Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
|BelkinModem.Belkin - 0 | 42 | 42 | 0 | 0 | 16 | 0 |
|lo0-plusnet.ptn-ag1.plus.net - 0 | 42 | 42 | 15 | 50 | 156 | 16 |
|ge0-0-0-103.ptn-gw2.plus.net - 3 | 42 | 41 | 15 | 48 | 125 | 32 |
|ge0-0-0-22.pte-gw1.plus.net - 0 | 42 | 42 | 16 | 51 | 156 | 32 |
|atm1-0.ptb-gw1.plus.net - 0 | 42 | 42 | 16 | 55 | 219 | 31 |
|vlan18.pri.ptb-gw4.plus.net - 0 | 42 | 42 | 31 | 59 | 141 | 31 |
|195.166.129.39 - 5 | 42 | 40 | 15 | 54 | 141 | 47 |
|212.159.8.137 - 5 | 42 | 40 | 31 | 51 | 125 | 47 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.7. Copyleft @2000-2001 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
Oh and here is the speed test i Did.
Your current speed is:
59.80kbps
Which means you can download at 7.47 KB/sec. from our servers. Our results show that your current speed is below the level we would expect for your product, you may be able to increase the speed of your connection by adjusting your settings. Please refer to our speed optimization page for more information on getting the most from your ADSL connection.
Anyone willing to give me a answer?
jgibbard
I am having exactly the same problem. The Internet is really slow, but all the PlusNet Fault Checks say its ok. It is ok from PlusNet-Exchange-Me, but the speed out on to the Internet is rubbish!
Check out my Speeds:
Date = Speed Achieved (kbps)
06-01-2006 19:42:28 = 70.7
06-01-2006 18:02:24 = 64 <-- Very Slow Cry
06-01-2006 06:56:06 = 962 <-- Seems to be ok when I'm in bed!
06-01-2006 06:52:18 = 963
05-01-2006 21:31:14 = 61.4
05-01-2006 21:12:13 = 58.7
25-09-2005 09:07:10 = 956.8 <-- Only started recently, good speeds a while ago
13-09-2005 17:55:13 = 957.2
13-09-2005 17:54:44 = 951.9
Whats going on PlusNet?Huh
Go to
http://www.internettrafficreport.com/main.htm
there you can see the current traffic for the internet and its live if you look on the right hand side you can download a FREE ITR client which will show the state of the net in your tray. It also show packet lose etc and this may show up if the problems are with the internet
thanks for the link mwright Cheesy
I must have been trottled to this speeds as I get 56k speeds 24/7.
Have you tried using the BT speed tester to rule out a problem at your exchange being the cause of this? You can find details of how to do this at http://usertools.plus.net/tutorials/id/27.
Tim
Here is my result from the BT Exchange
1917 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 217.47.108.125, your browser is reported as being Mozilla 5.0 and is running on Windows XP.
Seems like its on PLus. Nets side.
If you have not exceeded the SUP allowances, I would advise that you raise a ticket for this to be investigated, as you may be on an incorrect profile.
Tim
My usage is so far 8.59GB. I have raised a ticket.
Apprantly I have been put on a static IP to monitor my heavy usage on a unsuitible product. i am on BB+ and have only used 8.62GB. How is that heavy usage.
I believe I'm in the same boat as you. I used 11.something GB last month, nearly all web browsing and some streaming audio. I never use bittorrent or any other file sharing for that matter.
Raised a ticket, just have to see what response I get. I hope this ends soon, I hate having a 60kb connection speed when I'm paying for broadband. Sad
