Hyperlink in PlusNet Help does not work!
Trying to check on my connection speed so I went to the plusnet broadband checker, which has a message and hyperlink thus:
"You should then open your browser type http://217.35.209.142 into the address bar and click Go. "
This does not work! It is deceased, it is duff, this link is no longer extant, it has finished.
Can I have a correct link please?
1 REPLY
You cannot access the BT speedtester when logged into PlusNet. You have to login to the BT network as explained in BT Speed tester.
Can you post a link to the help page where what you have posted is stated?
