How to change Pn password
Alecto
I want to change my Pn password and can do the portal bit OK, but can't find where on my computer to change it.
The internet Options Connections bit only refers to dialup, and it's set to Never dial a connection. There's no mention of passwords in the Network bit of the control panel.
I'm on Win ME, IE6. I assume my router doesn't need it as well?
Yes its in the router you need to do it.
Basically set your new password via the portal and then log into your router and input the new password.
Chris
Alecto
Thanks Chris.
