How much usage
Andrea2006
How much usage
How much usage do you get with this service?
I am on premier 2mb
I dont roughly know how much i use per month, but what is the most i could use, without being over the top.
Midville
How much usage
I havent seen any hard or soft limits, so I cant say for sure. I would say 40 odd Gb, but dont quote me on that one Smiley. If you download any big files 'off peak' I am sure it would be ok.
Alecto
How much usage
This thread discusses the same question, if that's any help.
In short, there are no specified limits and Plusnet expect you to use your connection "sensibly". I wouldn't worry about it, unless you intend to hammer your line 24.7 in which case Plusnet is not for you.
If they do become unhappy with your usage, they'll get in touch and discuss it with you anyway. They won't just terminate your contract as some of the big names do.
You can check your usage any time for this week/month via
Connection Settings, top left of this screen, and then View My Usage.
