How long will my connection take?
Shockedops: several days now, would like to get it moving on, whats the normal time from application OK to ADSL up & on with yoruselves?
Stoof
holdtight
Start to finish seven to ten days if there`s no complications with your line and you can
check your order status here
mmmmm, yeah thx 4 that, I am six days in & order is at "checking your details"
Coooomon Plusnet lets get a shake on
Liam
Hi stoofer,
Your migration order is due to complete tomorrow. I've given it a prod and you may see that the Order Status has now updated.
At some point tomorrow you will experience a brief outage, and will need to reconnect with your PlusNet username and password.
Hope that helps!
Yes it does, thx 4 that, I have a netgear router, so I assume I just enter the details in that & were off, yes?
:shock:
Liam
Yep. Your username for connection will be stoofer@plusdsl.net and the password is the same you use to access the Member Centre.
Once the connection drops, simply login to the router, change the details and away you go.
And you should also be upgraded to Upto 8Mb (Max) at the same time.
Thx M8
Stoof
Liam
Just had a quick look at your account this morning.
Welcome to PlusNet :-)
