How long for regrade to 2mb
Anyone know what the average time is for the regrade from 512 to 2mb?
NG
My regrade to highest possible (by jumping the queue and paid for that) took them less than a day.
Phantom_Flan_Fl
My request went in on the 29th - I'm still waiting.
My 2mb regrade request went in on 29 Apr was activated yesterday 9th May so 11 days for me.
According to the schedule and guessin yer fae buckie the regrades will start free this month and there are multiple visits . If your from somewhere else check the list for your local exchange,it will give a ROUGH date. If you paid for a regrade it shouldnt take long i went to 1mbit took about a week.
http://www.plus.net/support/adsl/speed_upgrade_scheme.shtml
Mine only took 2 days this week to upgrade from 512k to 2mb.
kissack
My modem now reports
Up Stream Duplex 288 (Kbps.)
Down Stream Duplex 2272 (Kbps.)
so when can I expect +net to do their bit (speed tested still shows 450)
You need to contact support as BT are not always telling them that they have done the work.
They will then take the brakes off when you inform them that your seeing the higher speed on your router / modem.
kissack
Thanks John, I'll try that
kissack
Excellent. Didnt realise I had to request the free upgrade. Am there now :-)
Thanks John
Allan
So one has to request this free upgrade then?
You don't have to ask for the free speed upgrade.
You have to ask plusnet to remove the speed limit they have on your account. Normally this will be removed automatically once BT tell PlusNet the speed increase has been completed but sometimes BT are a little slow or just forget and you have to ask for it to be removed yourself.
Thanks for clearing that up Cheesy
Why can't PN take the brakes off on all accounts so that the faster speed will kick in as soon as it's available? It would seem to be a lot less complicated.
They have been asked if they can do this but apparently it can't be done on all accounts because some of the older legacy ones will need to be changed and this requires customer agreement. :?
It would make things so much easier and quicker for people who have just been upgraded if this could be done Cool
