How long does it take to be able to access a new mailbox??
I have setup anew mailboxe, reconfigured OE to get mail from it, but OE didn't recognise the details.
I went on to webmail, and couldn't login there either, how long does it take before you can use it??
Dave
Brickinit
did you recieve a "congratulation your mail box is ready to use" e-mail from plus net? if so it will be ready to use i'm sure i got mine almost instantly, also just check your settings in OE as it's easy to make a slip ( i know i've been there many times before,doesn't matter how many times you look at it it looks right until the last time ).
I can't even get access to the mailbox from webmail !
csogilvie
I think its about an hour - a copy of the welcome email goes to the Mailbox and Postmaster.
12 hours later - I still can't access it ?
Are you sure your using the correct username & password which you specified when you created the mailbox?
Check your contact us tickets and see if it shows a mailbox being created. You may need to view all closed tockets to see it. If no contact us ticket exists I would raise a ticket youself asking support to investigate.
csogilvie
I would give it 24 hrs before raising a Contact Us ticket - and they "Mailbox Created" ticket appears before they are active, it appears as soon as you create it.
If there is no ticket for the new mailbox it may indicate a problem occured when creating it.
csogilvie
True dat, but its no indication that it has actually been physically created (and getting mail which is what I thought you were implying.
Any new mailboxes I have created in the past have usually been operational within the hour (and often within 15 mins) so something has gone wrong here.
csogilvie
Agreed - I had the same problem yesterday, and it did become active within 24 hrs hence the comment up above.
See service announcement here which would explain the delay in activating the new mailbox.
csogilvie
Certainly my mailboxs have been confirmed as active now...
Ah - yes, working now !
Thanks all
Dave
