How do you tell if broadband has arrived?
Hi all,
How can you tell whether broadband has been turned on for your telephone line?
--Mike Peel
http://www.scifiminds.net/
There are two ways.
1: Wait for your ISP to inform you
2: Plug your ADSL connection equipment in (if you have any), and see if it sync's with the exchange.
Number 2 is not a sure sign that your will remain ADSL enabled, and only waiting until the ISP contacts you will gurentee this.
One way, if you've already got your modem or router is to plug it in to your phone line. Routers (at least) have a light labelled "ADSL" or "SYNC" (or similar) which shows a working connection.
Not foolproof but a good start. +Net only send out the equipment (if you've ordered it from them) after BT say the line is active.
At least, that's my understanding. Hope this helps.
Shall I shut up?
COOL web site. Added to Favourites. Gimmie Niven and Heinlein.
One way of telling is to connect ur modem in and if the adsl button no longer is flashing u r up and running, or plusnet will tell u
you could do what i did and plug all your gear in, and just wait, ( i had it set on auto connect) it immediatl;ey connected when my Line was activated Cheesy so then i knew, woohoo time to surf
marc
