How do you join PlusNet?
fotobits
Although I'm an adsl PlusNet user, I can't find the "entry point" on the PlusNet web pages that enable me to advise a BT Yahoo payg user how to join PlusNet as an adsl user, hopefully at 1Mbps.
OK if your an existing adsl user, but otherwise no options. Does a new subscriber have to become a PlusNet payg user first, before applying for adsl?
Regards
You can sign up for our residential packages online by visiting:
http://www.plus.net/products/residential/broadbandhome/
fotobits
Many thanks, Mark. On the following web page, after selecting the broadband option (1Mbps, 1MB) I was only getting the option "Existing user upgrade." The "buy now" didn't show. Hence my confusion!
It's rather odd, I've two browser windows open now, one gives only the "existing user upgrade" option and the other the two options.
Anyway, I hope when I advise my referral, it'll work OK!
Regards
fotobits
Yep, I've got it now, Mark. If I attempt to use the Residential/Broadband link when I'm logged in as a user, it doesn't work. However, if I log-off, then proceed from the link, it works!
Regards and thanks......
