How do you contact CS @PN
How do you contact the office by email or another way apart from using the phone
You need to work your way though the Help and support options until it finaly gives you the option to raise a question. Cry
Thank you wil give it ago
or to make it a little easier and to show you how the Help Assistant works ( and to test also )
You could look At This Video.
Regards,
Fixes: 57
the critical point is that as you are going through the options eventually a new window will open which shows the "Help Assistant".
Immediately closing that will show the original window which now has this at the bottom which allows you to ask the queston
Did this help?
The Help Assistant has directed you to a page that should help you.
If the page isn't useful, please make another choice.
> The page is helpful thanks.
> I want to go back and choose again
> Alternatively, ask your question to the Support Team
