How do i set up a static ip address
Hi there
I am currently trying to set up a static ip address for my broadband.I have followed instructions and done this correctly on my router but every time i log onto the net i am assigned a new ip.Even though my router is not set to obtain ip automatically.
can any1 tell me what am i doing wrong :?:
You setup a fixed ip on the portal and then everytime you login you will get that ip. Your router is still set to get a ip from dhcp but you will have the same one everytime.
I assume you do mean the internet ip not one for your own network
Thanks 4 the reply
yes the internet ip,I have installed bitcomet and i am having major problems with port forwarding.I think this is due to not having a static ip.
What product type are you on? Only certain products have a static IP option either by default or requestable.
Just a hunch, but give it a couple of hours.
Chilly
i,m on option 2 8gb cap at the minute.
Do i have to request a static ip
@neildalzell
Looking from your join date, I assume you're on a BBYW product, and not one of the legacy ones.
This explains the type of addressing based on account type
From this:
Account Type Default IP Address Optional alternative
Broadband Your Way (all options) Dynamic Static
I think that being an 'optional alternative' would mean a static IP would have to be requested via a ticket.
Not 100% though, maybe someone could clarify?
@ hunthome
Thanks very much that help topic took me to broadband setting and i was able to cange to a static ip.
Most appreciated
Thanks again
Port forwarding problems has nothing to do with a static internet ip unless you are not using NAT which 99.9% of routers use . To port forward the target pc mus have a static ip
