How do I set-up a Netgear 311 network card to zoomX4 Router
How do I set-up a Netgear 311 network card to zoomX4 Router, at the moment using a Sagem USB Modem having no problem with it, why do I want to change I am using Win2000 Pro I also have SuSE 9.1 Pro on computer, I have been told the best way to connect to suse is to use a LAN card, which I have installed. I would like someone to help me insetting up both of them at moment I can get into Router by http://10.0.0.2 which has a WAN, LAN, NAT Firewall, DMZ, DNS, Virtual Server, ADSL Configuration etc. For the Netgear card i'm supposed to type http://192.168.0.1 to setup but can't set-up cannot get into card to set-up. Thank you.
