How do I set up Alcatel Speed Touch USB ?
I am in the process of migrating to plus.net and so far I am impressed!
Currently I am using the Alcatel Speed Touch USB with BT Openworld.
Is there anyone out there who could let me know how to set up a new connection for plus.net (step by step) I am using Windows XP.
Thanks in advance,
Cathy
Smiley
You should only really need to change the username
to your 'username@plusdsl.net' or 'username@plus.net',
whichever is applicable and your new password.
You should currently have two types of software installed,
one being the Alcatel speedtouch connection which you need
and the other being the BT openworld software that customises
internet explorer which can be removed via Control panel -
Add or Remove Programs.
If you run into any problems then remove the lot and install
the full MS Windows version 3.01 from Speedtouch UK
You should only need to choose the English Uk option the rest
should be automatic.
It's a good idea to run the 3.01 'upgrade' version anyway if you are
still using the drivers from the original cd as those are quite out
of date now.
Alec.
Thanks,
I've got a while until the change over - I just want to be sure I know everything I need to do.
Cathy
