How do I know my lines activated????
Phantom_Flan_Fl
Got the activation and OK for use through on Thursday, my PCI modem arrived today.
My problem is simple, I can't connect, I get connection failure all the time.
I swapped filters and cables to no avail.
What more can I doHuh?Huh
RE: How do I know my lines activated????
Hi there Dave,
What kind of PCI modem is it? Have you checked your settings?
Regards,
Mike
| Mike Grice.....................Unmetered & ADSL solutions
| Customer Support......................for Home & Business
| PlusNet Technologies Ltd..............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Phantom_Flan_Fl
Thanks for the quick reply Mike.
It's a Creative 7430.
The VPI and VCI were already set to 0 and 38.
My only other concern is the ADSL mode.
There are 3 choices -
1. ANSI T1.413
2. ITU G992.2 (G.lite)
3. ITU G992.1 (G.dmt)
Option 2 was default.
I bought a longer line cable and I've noticed that one cable is straight through and the other is crossed on pins 3 & 4. Which is correctHuh
> 1. ANSI T1.413
You need it set to G.dmt
If you are plugging the device into a hub you need the crossed over cable. If you are plugging it directly into a PC you need the straight through cable.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
Phantom_Flan_Fl
Thanks Kevin,
Have to wait till tomorrow to try now as I'm at work.
Cheers,
Dave.
Phantom_Flan_Fl
Up and running now guys, thanks for the help.
Dave.
