How do I know if I'm on Tiscalli?
Serious answers please
Download 3100 kps
Upload 537 kps
Cheers
Alecto
Yes you are.
An upload faster than 448 indicates LLU.
Oh dear. Cry
If I ask not to be on Tiscalli will this mean my speeds will drop to pre "upgrade" levels
Alecto
Your upload will be 448k if you got to Max, but your download speed should not be less - may be greater on Max as Max uses a lower target SNR, and SNR normally reduces as your speed goes up.
If you are not having problems though, there is no need to change back from Tiscali. Many people are quite happy with their Tiscali service, I understand.
Thanks GP. Daily disconnections for last month or so . I'll take my chances with max methinks.
