How do I get my BRAS updated
geoffers
How do I get my BRAS profile updated?
Having experienced poor sync connections, I have moved my router to the main BT socket and the line seems stable so far.
Modem Syncs at around 4700 Kbps, but speed test only around 1/10th of this (470k)
Modem Stats report: Data Rate
Stream Type….Actual Data Rate
Up Stream…….448 (Kbps.)
Down Stream…4736 (Kbps.)
Operation Data
Operation Data..Upstream..Downstream
Noise Margin….21 dB……6 dB
Attenuation……54 dB……44 dB
However in my current ticket >>>>>>>>>>>>>
Ticket ID 19889908
Stephen Dean CSC Agent 5:38pm, Sunday 23rd July 2006
[internal] line synchign at 4672 k - bras profile not updated - set at 576. Line loss suggests better is possible. To goto BT to reset.
DSL MAX
Downstream Line Rate 576
Downstream Line Rate Timestamp 20/07/2006 07:16:07
Maximum Stable Rate Re-set (Y/N) N
Profile Change Time 01/01/1111 00:00:00
Maximum Stable Rate 576
Fault Threshold Rate 403
Interleaved Auto
+net will need to raise a request to BT for this. raise a service ticket
Dont call em they dont answer..
geoffers
ooops - spoke too soon....
....got home @ 5:30 pm & the sync light was flashing merrily Evil .
Eventually got a connection, but now the downstream data rate is showing as only 1152 Kbps (it's always been > 4500 K even though my download rate never goes above 450K)
Noise & Attenuation look fine - noise down to 4dB now I'm connected to master socket.
Operation Data Upstream Downstream
Noise Margin 8 dB 4 dB
Attenuation 56 dB 44 dB
+net will need to raise it to BT for you.
Which will result in interleaving being turned on if its not already
Raise a service ticket on the portal.
