How do I get line performance stats.
I've noticed several posts where people are quoting their line performance stats with reference to their ability to get the new increased speeds. Can anyone talk me through this please. I'm on the 500 (£18.99/month) package and on the 0191 exchange.
What ADSL equipment do you use? Many routers and some modems show line stats and that is the only place you can get full details. You can ask PlusNet to do a line test but you should only request this if you're having connection or speed problems.
Re: How do I get line performance stats.
0191 exchange.
Also your telephone dialing code is irrelavent. Dozens of exchanges can service the same dialing code.
Bit late
Sorry to be late in checking in. My modem isgiven as Alcatel Network Systems Inc. if that helps.
My exchange is Chester-le-Street 0191388----
Dosen't help. What exchange you are on has nothing to do with line stats.
If it is an ADSL modem rather than a router then very few supply line stats.
You will just have to wait and see what speeds you will get.
OK
I'll try and be patient. Thanks for replies.
