How do I find the DSL data on a Voyager 205 modem?
shermans
I am temporarily using a Voyager 205 instead of my Linksys Wireless router because I am having severe problems with VOIP (breaking up). I have therefore taken the usual router out of the equation. However, I do not know how to find the Upstrean / Downstream speeds, the margins and the attenuation data on this BT Voyager modem. Can anyone advise ?
Before I start raising tickets about this voice break-up, I realise it could be just due to slow Plusnet speeds - I seem to be getting verys slow speeds suddenly. My BT Test showed only 590 kbps which is half what I usually get. Any thoughts on that would be appreciated.
TVM.
1 REPLY
Liam
This should help you :
http://www.kitz.co.uk/adsl/frogstats.htm#anchor10
Give that a whirl.
