How do I find out if my exchange is being updated for 2Mb sp
I am on the Biddulph exchange in Stoke-on-Trent and was told that the line will not accept 2MB by PlusNet. How do I find out if the exchange is being updated to take the extra speeds?
1 REPLY
Its not your exchange which needs updated, its your line which is causing the problems.
It could be the distance you are from the exchange or the quality of your line.
Theres not much you can do to get the 2mb speeds in this case.
