How canI monitor my usage now??
BB+ user, how can I monitor the monthly usage nowHuh
dlmeter and other apps can be found on google, they will sit on ur PC and log bits /bytes/meg etc that you up/down load over X days/weeks etc, however if u use a router to connect you will ned to install this on all PCs and then check them regularly etc.
How about
Online Eye ?
Or even
NetLimiter ( its the lite version you want ).
Hope these help Smiley
Regards,
Ziggur
How about - check the Usage Meter.
Peak and Off-peak are now split for BB+ users. Smiley
