How big is a VP?
Stef
How big is a VP?
I learn't something yesterday Cheesy
a/ That BT VPs seem to start at 10MBytes/sec
b/ That the contention ratio specified is a fraction of the VP capacity (NOT the users copper loop max capacity e.g. for me at the moment 2MBytes/sec)
So to get more throughput/user there are two things you can change.
1/ You can either reduce the number of users per/vp (reducing the contention) or
2/ Increase the speed of the VP
Now '1' is under my control - I can choose to go to a lower contention product, but '2' is under BT's control.
I presume that BT must have a rolling project of upgrades (vps & associated hardware) to keep ahead of demand?
How big is a VP?
cool bit of info thanks, does that mean that you can request to be moved to a different vp with less users on it?
How big is a VP?
Unfortunatly not.
About the only time between are moved between VPs is during some migrations, during regrades (not in all cases) and where a VP is found to be overloaded (over contended).
However, you would have noticed by not if BT had supplied the service at 51:1 or worse.
