Host up to 3 domains at no extra charge?!
When I joined Plus BB I read about the above... However I couldn't find any info anywhere about this...
Any ideas or links etc :?:
Sorry if I put this in the wrong forum but I'm a newbie Cry
If you already own the domains it need not cost you anything further to have them hosted by PlusNet, but if you need to register the domains in the first place, it will cost you to do that. An option on some account types is to pay £1 per month for one domain, but you can actually register a domain name for less than this is you look around a bit, and can then "transfer it in". See the Domain names link on the left, and the further information available there.
THIS page should have all of the details you're after.
Thanx for your help...
Are you saying that when it says domains it means paid domains :?:
It means they won't charge you for hosting them.
But if you haven't already registered the domain names, then you will have to pay a registrar their services in that regard. On some account types, PlusNet does offer domain registration for £1 per month (and further domains can be registered for substantially more), but you will find companies which specialise in domain registrations are cheaper -- eg 123-reg claiming £2.59 per year for .uk domains. If you register a domain name through a third-party registrar, you then have to (partially) "transfer-in" the domain for it to be hosted by PlusNet; registering through PlusNet results in the domain automatically being hosted on PlusNet, so no transfer-in is required.
That's what I needed to know... Thanx for the info... Cool
