Higher speed = new modem?
thejudge
I'm thinking of upgrading from 512K to 2MB (it seems my exchange can handle it). Just one question:
I have the Dynamode A360 modem. Will this be able to handle the higher speeds, or will I need to get a newer/faster modem?
TIA
LiamM
You should have no problems using this modem on the higher speeds.
Most modems will be able to handle the new speed, even the old speedtouch usb is rated up to 8mb, as long as the upload speed is 1mb or below (and it will be) your ok!
thejudge
Thanks Liam. Diolch yn fawr, Rob.
(Might buy a new PC first, though...)
LiamM
PM'ed you Nigel Wink
