Higher Useage since 2Mb Speed upgrade
Richchad
Has anyone noticed that they are using more data transfer since the upgrade to 2Mb but not downloading, surfing anymore than before.....? Just because it is quicker it shouldn't increase your usage should it....?
What will it be like when we get 8Mb...!!
[Moderator note by acarr (Phil) :: Removed bold tags from the subject. They don't work there and just make a mess]
1 REPLY
There is a good theory on this that reads "The more you get, the more you want".
So yes, it is not unexpected to see usage increase when your speed increases.
In terms of a business view, the more efficiently your are able to do somthing, the more of it you can do.
