High-speed broadband? Get serious!
Below is a list of all the speed tests I have done since being with PN. If they are not a good reason for moving ISP, I don't know what are!
22-11-2006 02:08:12 126.3
22-11-2006 02:04:45 312.6
22-11-2006 02:03:20 200.6
22-11-2006 02:01:38 163.9
23-10-2006 11:08:42 376.2
23-10-2006 11:07:59 106.4
22-05-2006 15:08:35 1480.8
08-02-2006 02:23:29 732.3
08-02-2006 02:22:27 550.6
08-02-2006 02:21:49 711.4
06-02-2006 22:07:38 306.7
06-02-2006 22:06:54 320.5
04-10-2005 22:21:31 20987.2
04-10-2005 22:21:03 20969.3
I have BB Premier 1 "Up to 8 meg" - I wish I had "Up to 2 meg" :? , but after raising several tickets about my poor service, I have been fobbed off with excuses for the last time and am now looking into changing ISP.
Good luck, u cant really do much worse than pn..
Tell me about it. PN must be doing very badly if moving to AOL could be considered an "improvement"!
GersFans
Moving to dial up would be an improvement on this "service". It really is pathetic and seems to be getting worse.
[Moderator's note by James - (sallyandjames): Full quote of preceding post removed as per the link:rules]
Hi
have you checked your max stable rate through the portal. James has been doing some work recently on sorting out peoples profiles if they dont match the BT Delta reports. See thread here http://portal.plus.net/central/forums/viewtopic.php?t=51147
its worth a try!
Well, I've asked to be reviewed. If something isn't sorted in the nexy couple of weeks, I'm off to Pipex.
The best speed I have achieved on my up to 8meg (2 meg) service in the last 2 MONTHS is 150kbps!!!
The average 125 kbps (1/20th what I have achieved in the past)
Bye bye PlusNet
