High Ping
Nomad
High Ping
Hi hope this is in the right place? We have been on plusnet for about 15 months and play MOH and COD online but in the last couple of days we have noticed that the ping has gone very unstable ie used to be around an average of 25 and go up and down by only 1 or 2! now we have gone up to about a an average of 40 ping and it is up and down by as much as 30!! the server we play on is ok as the other players have no problem and our speed test if fine?? anybody got any ideas or can offer any help
Cheers Shockedops:
[Moderator's note by Liam Martin (martinfamily): Removed all CAPS title, Please avoid doing this.]
Nomad
High Ping
I have just done a trace and find that I have a problem as you can see over the 3 traces run the ping ms goes up and down like a !!!
HELP ANY IDEAS Cry Shockedops: Cry Shockedops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 56 ms 69 ms 25 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 19 ms 23 ms 22 ms ge0-0-0-901.ptn-gw1.plus.net [212.159.1.147]
4 23 ms 21 ms 27 ms gi5-0-23.pth-gw1.plus.net [212.159.4.20]
5 39 ms 130 ms 122 ms lonap-gw-a.jump.net.uk [193.203.5.80]
6 103 ms 23 ms 24 ms cs12.fpsclanservers.net [212.13.197.143]
LiamM
High Ping
The problem seems to lie mainly at Hop 5, outside of Plusnet's network, and therefore out of their control.
Give it a while, and things should hopefully return to normal. Thats the only advice I can offer.
Nomad
High Ping
Yep noticed that but we seem to be going up and down
a lot ie 2 56 ms 69 ms 25 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123] is this OK as before we were pretty constant? :?:
