Hidden functionality in PCI modem software - technical info
If you launch the Conexant AccessRunner Control Panel applet, there are four hidden keystroke options. One of them is referred to in the setup CD, the others are undocmumented. Where can I get a technical document which describes the functionality?
ALT+A = 6 tabs:
General/ATM link stats/AAL link stats
Autolog/Connection/Protocol setup
ALT+E = access code popup box
ALT+P = 10 tabs:
General/ATM link stats/AAL link stats/HAL diagnostics/Autolog
pHY layer stats/ Connection/line setup/Protocol setup/ATM OAM loopback
ALT+C = 3 tabs:
General/Line setup/Protocol setup
Cheers for any URLs, comments etc.
