Hi does a standard 2mb package need adsl?
as above. At the moment i have a Bt supplied Voyager 100 DSL modem
Will this be fine?
1 REPLY
I assume you mean a BT voyager 100 ADSL modem? or did you mean the 105
If so, it will work fine upto 8Mbs speeds.
and FYI the standard 2Mbs package is ADSL but I suspect your understanding of the technology is limited.
