Here we go again
Here we go again
Just come home , and the disconnections have started again.
Liam
Here we go again
I can see that you recently closed a fault with us.
If you'd like us to investigate and raise a fault to BT, please re-run the fault checker at http://faults.plus.net
Here we go again
I too am having loss of sync...
the Fault checker is not working beyond confirming phone No. and then initial checks then goes blank. The irony.
Here we go again
I closed a fault with you because it was a waste of time leaving it open, How many engineers do BT have to check all these faults. I do not require a response on here from you. I will communicate with you through the proper channels. By the way another lousy night of disconnections again, maybe it's the cars going by my house.
Regards.
Here we go again
PN strike Again.
