Here is new firmware for AR11 and AR41 Routers
As you may have noticed, Aceex dont seem to have any firmware available on their site...
I recently got the Aceex AR41 (with inc 4 port switch) router from ebuyer and hunted round on the net for newer firmware and luckily found some from another company!
Both the AR11 and AR41 use the same firmware so this should be ok....
The AR41 is the equivalent to the SP3352 on Micronet's website.
and ther AR11 is the same as the SP3350 but the firmware files are identical.
They may have different cases but i believe the insides to be identical.
I have been using the Micronet firmware for about 2 months now with no problems.
If you are not sure then here are both the links for firmware.
For plusnet, you need the Annex A version which is the firmware that has the A after the version number
The firmware version currently on the site is 2.7t
AR11 FIRMWARE
http://filesrv.micronet.info/Download/Driver/ADSL/SP3350A_27t.zip
AR41 FIRMWARE
http://filesrv.micronet.info/Download/Driver/ADSL/SP3352_27t.zip
Micronet AR11 page
http://www.micronet.info/Products/ADSL/SP3350A.asp
Micronet AR41 Page
http://www.micronet.info/Products/ADSL/SP3352.asp
Micronet Download Page
http://filesrv.micronet.info/Download/Driver/Driver.asp#adsl
Another site also has links to firmware for the Ar11/AR41...
http://www.anbro.de/
they have firmware version 2.7t but i couldnt get the download to start for some reason, and the site is in german!!So dont be surprised if the firmware is as well......
anyways, hope this helps some people,,
cheers
cRuNcHiE
RE: Here is new firmware for AR11 and AR41 Routers
I forgot to mention you will need a little util to upload the firmware as well.....
its called TFTP
ive uploaded it here if anyone wants it..
http://www.iamcrunchie.plus.com/!firmware!/tftp.zip
theres a readme explaining what to do...
just run the app then point it to the folder where the firmware .img file is, then goto the firmware admin page and press update firmware..
PLEASE NOTE!!!!
If you have a really old version of the firmware on your router it may not give it enough time to upload the firmware and will give an error message...
If this happens you will have to upgrade via Telnet..
Just do this..
Start>Run> Telnet 192.168.8.1
then goto the firmware upgrade bit (you still need the TFTP app loaded) and it should work this time..
laters
cRuNcHiE
bluewhale
Do you know if theres anyway to get vpn working with the ar11?
bluewhale
you might want to post this on adslguide...
dont know anything about VPN on them im afraid!
Lorian
Ar11 does not support VPN's.
Jc.
