Help!!!
Help!!!
I am with Plus.net and using a SAR705. Now I am facing constant disconnect problems and what's worse the router clashes some times. I read a news here http://www.adslguide.org.uk/newsarchive.asp?item=1312
which stated the compatability issue between the SAR705and BT wholesale line(virata chipset and Cisco gateway?) .
Is anything I could do for that?
Or I need to buy a new router?
Many thanks
[Moderators note (by Thomas): CAPS removed from title. Please refrain from posting things entirely in capital letters.]
Help!!!
I suggest you give Solwise a ring to check if it is a duff router, or you could post a message on the Solwise forum
It's was OK
But suddenly doesnt work properly
